Spb wallet Mac client just crashes
I recently installed SPB Wallet Mac Client 2.0 on my MacBook Pro to protect sensitive information.  The program just crashes when launched.  What could be the problem?  I have a MacBook Pro that has a 2.5 GHz Intel Core i5, 8 GB RAM and OSx Snow Leopard.
Best Answer by Darrel R Gonzale
Answered By 0 points N/A #132284
Ensure that you are running SPB Wallet Software with Mac OS X Version 10.5 or higher. And you have installed the SPB Wallet Desktop Component for Mac and not the mobile version. For all I know, this software is specifically designed for mobile. Also, ensure that the SPB Wallet software is not corrupted. Try to uninstall it from your computer and go to their official website and download the software from there. Then install it again to your computer.
SPB Wallet Software Official Website
Answered By 65 points N/A #132285
Hi Neil,
The proper installation for spb in order to run it in your device are the following:
1. Install crossover. You can buy this online. This is a separate installation from your spb wallet.
2. If you persists installing it, then launch crossover from your OS application menu.
3. Install hardware, select other application.
4. Follow the instructions for installation.
