Specific email check for virus
An email attachment received by me has not been flagged as a virus by MDaemon but I think that it contains one.
How can I check this?
How can I scan the virus by running the MDaemon?Â
Hello Dear!
This problem has been cured by MDaemon antivirus which is specially designed to scan your emails in connection with plug in software works correctly as well as accuracy.
It is very important that when you install a third party software package like MDaemon and scan your files and folders, in the scanning process the software should exclude the system files and folder from scanning, it will call real scanning.
If any software leaves this feature then it would difficult to drain all faulty files or cure total files from your computer system.
Note: Now, I tell you why this is important. Because the antivirus system folder contains the infected or quarantined files in these folders but they are inactive files and should be deleted just through the software.
Good Luck
SecurityPlus for MDaemon comes with the latest generation of antivirus made to provide spam protection to the MDaemon Messaging Server.
It should detect problems with viruses in attachments, but certain issues may occur when you use another antivirus on your computer. This one should not affect MDaemon’s integrity in any way. Therefore, the MDaemon folder should be excluded from scanning by the other program.
Failing to do so would result in unexpected actions, such as MDaemon components put into quarantine, loss of e-mails or corrupted e-mails.
