Hi, I need a help, How to read leica gsi files in windows 7? Is there any specific software to read leica gsi files please send the download link to download that software. And send some helping tutorial explanations for how to use that software, Special features, Main advantages and disadvantages.
Specific software to read leica gsi files
Hello, Christopher
It’s simple software, it has some tool to convert the document like pdf to word, word to pdf, converting picture at that format which you want, it has some features like line reading that make reading long text file and documents easy and convenient. Leica Digital capture option means it is enables you to operate your leica M8 from computer, Leica X change mean that provide link between system and Autodesk 3D. Here is the link.
http://top.windows9download.net/list/leica-gsi-files-to-txt.html
Hello ChristopherVBrown,
If you want to read the lica gsi files in windows 7 then you have to use a third party software so that you can convert then in text file after that you can easily read those files easily from your windows platform. Here i am giving you some of the link from where you can get the software named as "All to text " and by using that software you can easily convert your files to text.
Also there is another software that has the same purpose but that is specifically for Lica gsi. The link is given below.
http://softwaretopic.informer.com/reading-leica-gsi-files/
Hi Christopher,
Leica Digital capture option means it is enables you to operate your leica M8 from computer, Leica X change mean that provide link between system and Autodesk 3D. It’s simple software, it has some tool to convert the document like pdf to word, word to pdf, converting picture at that format which you want, it has some features like line reading that make reading long text file and documents easy and convenient. Leica Digital capture option means it is enables you to operate your leica M8 from computer, Leica X change mean that provide link between system and Autodesk 3D.
Here you have some link:
vishwa
Hello Christopher,
I think I have a solution for your problem.
You can read leica gsi files in Windows 7,but you must use third party software (it means And 3rd party is an independent software company making something that works with windows or any other OS).
The best software you can find from here.
If you don't like to buy get it free here.
There are more benefits in this software,main benefit is you can convert any format to txt format by this software.
