Specifications of Microsoft Smart Glass’ availability to other hard wares
What are the specifications regarding its application to other hardware of this newly introduced Microsoft Smart Glass?
Dear Lindakcarico
Smart Glass is actually not a devices not is any hardware, it is basically an application. It will work with operating systems such as Windows 8 which runs on PCs as well as on mobile devices, Google Android operating system of mobile phones and is also programmed to work with Apple devices e.g. iPhone, iPads etc.
Smart Glass links up smartphones and tablets with Xbox and TVs. According to the Microsoft officials, they are not only trying to combine all features in this Smart Glass which were given in earlier similar applications but taking it further. A user can send a show or movie watching on cell phone to TV or vice versa.
I hope this will help answering your query.
The Microsoft Xbox SmartGlass is not an additional hardware that you install on your device. It is actually an app that you download and install on a compatible mobile device. Once SmartGlass is installed, you need to enable SmartGlass support on your Xbox. On your Xbox, go to “Console Settings,” “Connected Devices” then select to activate SmartGlass support.
Once SmartGlass support has been enabled, you just need to launch the SmartGlass app then log in to your Microsoft Xbox or Live account. After this, you may now ditch your joypad and use your mobile device to view and interact with SmartGlass-friendly games, applications, music, and video. To get the app, go to Xbox One SmartGlass on the Microsoft Store.
The SmartGlass app requires a Windows phone with Windows 8 Mobile operating system.
