The specified file is not a registry script
We need help on the registry related error on our PC since my brother needs to do some squeezes on it.
We are running out of ideas and options on how making it work.
Altering too much stuff on the computer might cripple the Windows system in the end.
Tweaking the system is good because it sometimes makes an improvement in the access speed of the computer and makes you do some customization on some of the Windows components.
Maybe there is something wrong on how you do the import and export of the registry.
If you want to copy all of the entries in the HKEY_CURRENT_USER of your old computer:
You can now copy the registry file to the new computer and do the registry import there.
There should be no problem when transferring or copying registry entries using this procedure.
