Specs of Linux; Why are they very low?
60 points
Posted on - 02/04/2015
The specs of Linux are very high compared to that of Linux. 'Newer the version, higher the specifications' is the case with Windows. But the specifications of Linux Distros are almost same all the time. Why? What's special is there in Linux Kernal which makes it easy to operate in Low Specs PCs?
