Speed DSL internet type connection
How can I speed DSL connection type internet? I am using reliance netconnect modem. But the modem speed is very low.
You can do increase in the speed using some software. There are many possibilities due to which you DSL speed in not working correctly one of them is your LAN is not good enough to give you the high speed. Another is your line connection is not good and the wire coming to your DSL is not good so the speed is very bad.
You can increase your speed by using some of the software which is easily available on the net.
You can search out the software’s on Google which will help you increase your DSL speed. Before this check out your upload and down speed through speedtest.net on this site you can check out how much speed is of upload and also of download.
If the speed of down is fine then no need of using software’s but if the speed is very low then use software’s to solve this issue.
If it is an ADSL modem then it must support up to 10 MB else you have to change your modem or somehow it might be the modem's setting issue if your modem is supported or it might also be the line quality issue i.e noise ratio, distortion, attenuation etc.
That means there must be any condition either good line or poor line depending on the package.
Notifications
