John Parker
20 points
Posted on - 03/11/2012
I am using an older version of Idm(Internet download manager) and I cannot find the speed limiter option. I want to know how to set speed limiter or how to find it so that I manage the download speed. Should someone know about where to or how to set/get this settings, please do inform me.
John parker
Speed limiter is not showing on idm download screen.
Hey john!
No doubt Internet Download Manager (IDM) is one of the best download manager. I also use Internet Download Manager to download my files from the internet.
Speed limiter option is available on Internet Download Manager. You can find this option in simple steps.
What you have to do is, open your Internet Download Manager.
On the top of the Internet Download Manager, you can see a toolbar, there you can see an option "Download".
Click on it, a drop down list will open, Select the second last option "Speed limiter". click on it and go to settings.
Here set your speed limit and enjoy your Internet Download Manager.
Thanks
Open your Internet download manager and then on the top you will see the downloads tab and then click it and it will show a list of tabs and then you will see the speed limtier and then place your mouse cursor on Speed limiter and then a new set of choices will appear click on turn on. And then click downloads > speed limiter and then click now on settings for you to set the specified limit you want Internet download Manager to use, after configuring click ok and then now your Internet download manager has a set limit on downloading the files you want to download.
