I have used all those versions of Windows and I have seen that windows XP is a lot faster than Windows Vista also windows Seven is much better than Windows Vista. Now I want to know is it possible to speed up the system?
Speed up the system of windows vista.
No matter how briskly or shiny computers may be once they are new, all of them seem to get slower over time. That PC you purchased last year may not feel like such a screamer once you put in a lot of programs, applications and tools, and transfer much amounts of junk from the web. The delay may happen therefore bit by bit without you noticing it, till sooner or later you’re attempting to open a program or file and you will wonder what happened to your PC.
Whatever the cause, there are lots of how to assist to speed up Windows and create your computer work better even while not upgrading your hardware. Here are some tips to assist you optimize Windows vista for quicker performance.
Remove all unimportant programs.
Ensure to clean up your hard disk.
Limit load of application.
Defrag your hard drive once in a whole.
Turn visual effects off.
