Speed Up The Computer With Windows Error Reporting Files
There are so many files in our system. Some are the error reporting file so, how to view and delete the windows error reporting file?
Steps to view windows error reporting files:
• First click on the windows icon and type control panel.
• Then go to system and security.
• Open Action center.
• Then click on the view problem to report.
Steps to delete windows error reporting files:
• Click on the start menu and type the control panel.
• On the right corner, you see the view by then select the large icons.
• Then click on File Explorer Options and enable Hidden Files view from the menu.
• Go to C:\ProgramData\Microsoft\Windows\WER\.
• Here you will find the bunch of folders including LocalReportarchive, ReportArchive, ReportQuese, and Temp.
• You will open each of these folders and delete all archive files.
