Speedtest Bandwidth checker ipad mini question
I recently installed Speed Test Bandwidth checker iPad Mini LTE with the A6X chip.Â
Can Speed Test Monitor the Bandwidth usage from WiFi instead of the cellular data usage?
Hi Wilton,
Speed Test is a great application when you would like to know the maximum download Bandwidth speed and upload Bandwidth speed of your internet connection using your Android device or Computer.
You can also check your ping, Internet Service Provider’s location, and even rate them with if you are satisfied with their services.
Speed Test can definitely monitor both of the internet speed on WiFi and in cellular data usage (3G or 4G).
I hope this helps.
