Spelling and grammar is not working
I am using MS-WORD 2003 version. It was working good. But from some days it not working properly.
Spelling and grammar is closed. I have tried to find out it. but I'm not founding.have any solution?
Hi Mahfujrahat,
I actually faced the same problem once in the past and here is what you need to check:
in any of your documents select all by pressing CTRL + A and then go to tools > language > set language and make sure that "do not check spelling or grammar" option is unchecked also click default button to make the change last permanently. also uncheck the option "detect language automatically".
Also go to tools > options > spelling and grammar tab > make sure that "check spelling as you type" & "check grammar as you type" & "check grammar with spelling" are checked.
Hope this helps.
I am very sorry for this inconvenience.MS Word 2003 version are Microsoft Word for windows since 1995.
There are certain answers with regards to your problem. So, here are the following steps that will lead you to resolve this issue.
If the spelling or grammar is closed or not working, you need to double check the following:
1. “MENU BAR”
2. Click on tools
3. Click on Spelling and Grammar
4. Click Options
5. Uncheck Check Spelling and Grammar as You Type.
And in grammar checking you need to do this:
1. Right Click where it is underlined with a green line.
2. And a new window open, you just need to click on the “EXPLAIN BUTTON” located on the lower right side of it.
Thank you.
And hoping it will help you.
