Hopkins
600 points
Posted on - 06/02/2011
So far I have used two mail clients. One is Outlook Express and another one is Eudora which I am currently using. Previously, I was using Outlook Express and due to face some technical errors I transferred into Eudora. I think that Eudora is a strong and secured mail client and enjoying great service.
But the spelling check option is not working from this morning. The spell check option is still there in the tools menu. As a part of try I do uninstall the program and reinstall it again. I get back the spell check error option and it was also working but only for one hour. After 1 hour of normal service, it vanished again.
Please help me.
Spelling Check is not Working on Eudora Mail Client
Hi Hopkins,
Spell Checker in Eudora is one great tool. It checks the spelling as you type the word. This Spell Check tool can be turned on or off. It can be the cause why it is not working on your end. To enable spell check please follow the steps below:
Select on Tools then Options.
Go to Spell Checking category
Be sure to have the Spell check enabled
Click on OK button
Also, please make sure that you have the required dictionaries in your Program Directory. There will be a .tlx and a .clx file for each dictionary.
lee hung
75 points
This problem might be due to conflict between two versions of Eudora. Sometime it happens when we don’t remove the old version and download the new version. Thus due to the presence of two versions such types of problems may occur. Try the following options:
You first need to delete the old version and afterward again download new version of Eudora.
Secondly this problem can also be resolved by rebooting your PC.
Before downloading new version of Eudora, you must use PC cleaner.
Try these options; hope your problem will be resolved.
Eudora is an email client developed by Steve Dorner in 1988 used in the classic Mac OS and OS X as well as the Microsoft Windows operating systems. It supported several palmtop computing platforms like the Palm OS and Newton. The software was open sourced in 2018 by the Computer History Museum after years of being out of print.
The email client was named after American author Eudora Welty because of her short story “Why I Live at the P.O.” For users who want to try it, you can download Eudora 7.1.0.9. This, I think, is the latest stable version because all succeeding versions were all beta versions until it got discontinued.
For a good reading about the Eudora email client, visit The Eudora Email Client Source Code.
