hannahwtc
10 points
Posted on - 08/17/2012
Hi expert
I used Spybot S&D Hijackthis, msconfig as well as I ran AVG AntiVirus without any effect.
Either I found nothing strange from Hijackthis.
I don't remember anything that might occurred this, and already I have some programs planned to block like that thing (Spyware Blaster).
Here is the error:
Please help me to solve it.
Spybot S&D Hijackthis, msconfig and AVG AntiVirus
Hello there buddy,
My suggestion to you is if you can change your antivirus into Microsoft security essential I think you better switch to that because in my experience it is better than AVG, first thing you should do is turn of all the start up in ms config. then reboot your computer.
And download the Microsoft malicious software removal tool here link, after downloading just run it and scan your computer use the complete scan and give it some time. because it will take you 3 to 5 hours if you have lots of stuffs in you computer.
But this tool is very effective on cleaning your computer.
Hope this suggestion will help you solve your problems. Have a nice day.
