Davis Avon
20 points
Posted on - 08/23/2012
The other day spybot was working fine, I thought it was still running fine but when I tried to open it, it gives me this error about dll file, should I uninstall it and get a much better protection?
Spybot – Search & Destroy
Failed to load C:Program FilesSpybot – Search DestroyDelZip179.dll
Unexpected error in fixing problems
(Out of memory)
Spybot search and destroy dll error
Hello Davis,
Maybe your files have corrupted? Try uninstalling and install it again. Note that after you have uninstalled the software; make sure that there are no remaining fragments on the registry, and everywhere. You could use software that can do this task. If this doesn’t work, there is a possibility that your DelZip179.dll is corrupted and already damaged. If this is the case, try sending an email to the Spybot support. Their email is [email protected] or visit their web site
There are a lot of people asking help for the same problem. Others just contacted the distributor of the software using the above email and website and their problems were solved. I hope this could help you in a way.
Good luck,
Reaiu Hathy
