Spyware Detector unins000.exe Message Error
Hi all,
All the time I had the Spyware Detector.
I have run Spybot as instructed. It found 195 problems, all of which were related to Spyware Detector and it now seems to have removed Spyware Detector, which was a full version that I paid for. I can re-install as I have the reference number but should I do that?
Spybot mentioned that SD is installing viruses that detects and tells you to buy the full version in order to remove them. Is this true or is it just bitching between rival anti-spyware organizations? As I had the full version, it should not have been a problem for me anyway.
The error message that appeared to me is :
"D:Program FilesSpywareDetectorunins000.exe
A referral was returned from the server".
Any help?
