Jo Opheim
65 points
Posted on - 02/08/2013
Will someone help me? Last day, I installed SpywareBlaster on my system without any hurdle, but at this time, I tried to upgrade it and received an error. Fruitfully it installed, however on the other hand when I attempt to explore the software , an error message occurs which you can see at belowÂ
Quote:
Error! Error while unpacking program, code 2. Please report to the author.
Specifications are Windows Vista, 64 bit version.
Some idea?
Thank you
SpywareBlaster Error Code 2: Error While Unpacking Program
Hello Jo,
Thanks for choosing us. About your concern, you get this error while unpacking Spyware Blaster. If you get this error while unpacking Spyware Blaster, follow these following steps listed below to remove this KB2533623 Windows update and check if it helps:
Click "Start > Control Panel > Programs and Features".
Click the "View installed updates" link on the left side of the window.
Locate the "Update for Windows Vista for x64-based Systems (KB2533623)" update.
Select the KB2533623 update and then click the "Uninstall" button.
Once the update has been removed, restart the computer.
The upgrade does load every time so you need to restart and remember to disable automatic updates or delete KB2533623 every time.
Please let me know if I can provide any further assistance.
Have a good day!
