SQL 2012 iso file size
Hi TechyV users!
Is the Sql 2012 iso file size big? How many are them? Can I download it from the Microsoft Website? Are there requirements that are needed to install it?Â
Thank you very much
Desiraealexa
Hi TechyV users!
Thank you very much
Desiraealexa
Iso file for Microsoft SQL Server is 4.2 GB. You can download from this website: http://www.microsoft.com/en-us/download/details.aspx?id=29066 by clicking on Download on file name ENUSQLFULL_ENU.iso from Files in this download section. You can download as DVD image Microsoft SQL Server 2012 Evaluation. When the downloading is over, open some Burning Software for DVD and select to burn the empty DVD that you have previous inserted from an Iso image. Then for the file to use choose the image that you have downloaded. When burning is complete, double click on Setup.exe from DVD disk to begin the installation.
Williamson Mellisa
