SQL Cluster diagrams in Visio
Hi All,
I need SQL Cluster diagrams in Visio, Is there any Wizard that will help me to have the planning structure diagram of SQL Cluster in Visio.
Thanks & Regards,
Scott Athers
Hi All,
Thanks & Regards,
Scott Athers
Hello Scott,
Good day!
You are finding some wizard to help your planning structure of SQL Cluster in Visio. I will give you the process on how to install Visio 2007 add-in for SQL Server infrastructure Diagrams
Step 1: You need to fire up the Visio Start/All Programs
Step 2: Look at the top
Step 3: Go to Configure
Step 4: Use Wizard by clicking small button and then click next.
Step 5: The Servers. You need to specify how many servers you need to put up and then click next.
Step 6: Start
Then you Click Save and do it for the next server. You'll get asked if you really meant that in a Vista style but hey ho that's the way of the world nowadays.
N.B. A few little pecularities emerge.
If you want to select a cluster be very sure to select at least two servers before progressing to select sql server versions. If you fail to do this you will not be able to select the "Enable Clusters for SQL Servers" check box that I have cunningly hidden with my drop down for Step 6.
Step 6a: Clustering checkbox
As you have noticed, there are plenty of nodes and storage options.
Step 7: Repeat to complete the process
Step 8: Summary
Step 9: Visio is now working
Step 10: Visio successfully created
Step 11: Finally
Notice that by clicking on a shape and looking at the shape data out pops all that metadata we spent ages adding in. The good news is that this data is totally amendable so I can RTM my windows 2008 server which my clients will be pleased about.
Anyways if you fancy a play you can always download a copy yourself. It is better than nothing I wouldn't say by much but it is albeit small step in making Visio useful to a much wider audience. I find only Microsoft Project to be more unwieldy than Visio. Perhaps that's just me…
Visio needs shapes and addin's like this in my view that anyone can download and install. The frustrating thing I find is that it could be such a useful tool – but often it just winds me up.
It would also be a lot more useful if it was updated to have all the latest and greatest Server OS and SQL Server combinations. Given how new this download is I'd say it's a shame that it's content is already out of date.
