SQL Interaction software Error issue
Ok let’s sort out this problem if you can. I have software which runs with SQL Server. I didn’t have access to that software database. Actually I can still access its password, so I can generate reports from it. Yesterday I was working on the software and was trying to get a report from it about the whole day's work and then the SQL Server automatically gave this error as in the image that there was an error with reading results of the SQL statement.
I didn’t waste time and just re-configured MYSQL Server along with its database and then reconnected the software to it and once again I tried to draw the reports out, but I got the same error. And now I am stuck and can't move forward with my work because I need daily reports of it. Does anyone know what should be the solution of this issue. Is there any proper rectification of it.
Interactive SQL
There was an error reading the results of the SQL statement.
The displayed results may be incorrect or incomplete.
Deadlock deleted
SQLCODE=-306, ODBC 3 State=”40001”
