I get the following error message when a new value is entered into the combo box (cboBookCategory): I am not aware with these issues so I need your help to fix this issue. How can I fix this problem? Have any solution. Thanks in advance.
Book reviews:
Book ID: 1
Book Title : Stams Tech Yourself SQL in 10 Minutes
Book review:                    Unknown Book Category…
‘SQL’ is not currently in the list.
Do you want to add it?
SQL is not currently in the list
Hi Robert,
It looks like you are just the end user of this form and not the developer of the application. You are getting this error because you are trying to create a new category that is not part of the existing list of categories. For this input box, it is a dropdown and you will have to choose a value from the list. Adding new items to the list is probably not enabled. You can communicate to the developer that you need a new category called "SQL" added to the current list. In fact, in the above pop up that you are getting, click the Yes button and see if it adds the SQL value to the list.
