SQL problems on expressions would not work
Is there anyone who has discovered that SQL expressions cannot work with the word “between” for the shape file?
But otherwise it can work if an equivalent is used for example “SELECT*then the variables given.
What other options should I use?
Anyone with different opinion, please give your helpful tips on this
