SQL queries for beginner and processing module
What are the methods that I should follow for the preparations of making a table? What are the disadvantages of using SQL? What does the Join Between Tables in SQL means? Can someone explain the distinctions between the Embedded and the Dynamic SQL and the 2 and 3-tier architectures? What is the difference between SQL and QBE?
