SQL Remote Connect Error Due to FireWall Disabled
Hi dear,
I am a new user of SQL Server and I am receiving the below error. I tried to install this software in an environment where, security is enabled by admin. According to my point, this error is due to firewall being disabled or TCP/IP error doesn’t know correct reason.
Please tell me its reason and solution.
Error Detail:
Connect to Server
Cannot connect to istw1849.
Additional information:
The client was unable to establish a connection because of an error during connection initialization process before login. Possible cause include the following: the client tried to connect to an unsupported version of SQL Server; the server was to busy to accept new connections; or there was a resource limitation (insufficient memory or maximum allowed connections) on the server.
(Provider: Named pipes, error: 0 – No process is on the other end of the pipe.) (Microsoft SQL Server, Error: 233)
OK
