SQL server 2008 standard edition
When SQL 2008 standard edition is run, an unhandled exception occurs with the error code "0x84B10001" and the set up fails. What must be done to successfully install and to run the same?
Hi
SQL server 2008 will be provided as one downloadable file with new features and the fixes from the previous versions too. One of the common reason or cause for this type of error may be improper setup or installation of the previous SQL server. This corrupts the registry and then this leads to the corruption of installation process. As the SQL server is a cumulative release with all new hot fixes, the solution for this type of error is updated in ‘cumulative update package 5 for SQL server 2008 edition’. This can be better solved by using the most recent updated cumulative service package.
That error is the result of not searching for the product’s system requirements which is usually the first step prior to installing the program. The error is very minor which only requires installing Microsoft .NET Framework 4.0 to fix the problem. Go to Microsoft .NET Framework 4 Standalone Installer then download and install it. Once this component is installed, re-install Microsoft SQL Server 2008.
For more info on the system requirements for Microsoft SQL Server 2008, go to SQL Server 2008 Hardware and Software Requirements. Microsoft SQL Server 2008 is the thirteenth release of SQL Server dubbed Katmai. It was released on August 6, 2008 when it was announced at ESRI 2008 User's Conference to the SQL Server Special Interest Group by Ed Katibah, Spatial Program Manager at Microsoft.
It is designed to make data management self-organizing, self-tuning, and self-maintaining with the development of SQL Server Always On technologies which offers near-zero downtime. It also includes support for semi-structured and structured data as well as digital media formats for photos, audio, video, and other multimedia data.
SQL Server 2008 can be a data storage backend for unlike varieties of data such as time/calendar, XML, spatial, email, file, document, and others in addition to performing search, sharing, query, analysis, and synchronization across all data types.
Notifications
