SQL Server 2012 installation Failed-Error 1330
10 points
Posted on - 01/28/2013
As I was trying to install SQL Server2012 the following error was displayed:
Microsoft SQL Server 2012 Setup
The Following error has occurred:
Error 1330.A file that is required cannot be installed because the cabinet file D:1033_ENU_LPredistVisualStudioShellVSIntSetupcab12.cab has an invalid digital signature. This
may indicate that the cabinet file is corrupt.
                                              OK
I am guessing there might be a problem in the cabinet file.
Unfortunately I do not have any other ideas but to install the SQL 2012 (since RC) till RTMÂ
(This file may be corrupted following the message). I tried like six times but, failed. However, I installed that into Oracle Virtual Box pretty easily. I have attached the screenshot.
PLEASE HELP!!! I really need this!
