SQL Server Operating System Error 995. Any Fixes?
While using the SQL Server, I faced an error, operating system error 995. Does anyone know how do I resolve this issue without any hassle?
Hello, this error signifies that the Input-Output process which is an ongoing process during a backup or a restoration is having a problem.
Usually, we face an error because the backup medium is full.
To fix this, you can follow these methods,
Above steps will lead you to the solution.
The full error reads:
“Error: 18210, Severity: 16, State: 1
BackupMedium::ReportIoError: write failure on backup device ‘VDI_ DeviceID’. Operating system error 995 (The I/O operation has been aborted because of either a thread exit or an application request).”
There are several scenarios when you encounter Operating System Error 995 when using SQL and here are some:
You can fix the problem by splitting or dividing the SQL database into multiple policies which will back up several databases individually at a specific instance. Another way is to increase the physical or virtual memory of the computer.
