The SQL Server Service Failed To Start, How To Solve It.
If u see the message, The SQL Server 2005 service failed to start, while installing. How To Successfully Install SQL Server 2005 In Windows?
Error:
Sometimes, the SQL Server service may fail to start. It may be displayed as shown below. Error Message:
Step 1: [For Windows XP] Don’t click on cancel, let it be on screen. Give “EVERYONE” full control permissions to “Protect” folder Select Show hidden files and folders Navigate to: “C:Documents and SettingsNetworkServiceApplication DataMicrosoft” And Give “EVERYONE” full control permissions.
Step 2: Don’t click on cancel, let the message be on screen, rename “Microsoft” folder in the below path. Select Show clouded files and folders
Step 3: Always run the SQL Server setup as “Run as Administrator”.
Step 4: Create an “empty” registry key name as ‘Domain’: Click Start | Run | type Regedit | Click OK. Go to: “HKLMSYSTEMCurrentControlSetServicesTcpipParameter” Right Click “Parameter” | New | String Value | rename as “Domain”
Step 5: While installing SQL Server, choose “Local System” for Service account.
Step 6: Switch OFF the “Firewall” Click Start | Run | type firewall.Cpl | Switch Off | Click OK.
Step 7: Pause or disable the antivirus Before installation of SQL Server
Step 8: Increase the Event Viewer log size to large value. Click Start | Run | type event or. Mac | Click OK. Right click on Application then, Properties then, Change maximum size. And Check “Overwrite events when needed." Click Apply and OK. Note:
1. Always login to the system as an Administrator account.
2. Software requirements for SQL Server 2005 sp2:
Microsoft.NET Framework 2.0 Windows Installer3.1
Microsoft Data Access Components (MDAC) 2.8 SP1 or later.
Microsoft Internet Explorer 6.0 SP1
3: Let the error message be on the screen, Transfer [SqlOS.dll and SqlServr.exe of SqlFix] to SQL installation path [C:Program FilesMicrosoft SQL ServerMSSQL.1MSSQLBinn] and click OK.
Download: SqlFix
4: The SQL 2005 family does not support following processors AMD K6-2 processors, AMD Phenom 8400 Triple-Core processor, And Intel Xeon X5680.
Notifications
