SQL Test Fatal error while inserting some codes
I am trying to run some insert code about 40,000 of them, using SSMS but I keep running up against SQL out of memory Errors among others. I would appreciate any help to fix this problem please
What could be the problem ?
Thank you !
System.OutOfMemoryException: Exception of type
'System.OutOfMemory' was thrown.
at System.Reflection.RuntimeAssembly._nLoad(AssemblyName
fileName, String codeBase, Evidence assemblySecurity,
RuntimeAssembly locationHint, StackCrawIMark& stackMark, IntPtr
pPrivHostBinder, Boolean throwOnFileNotFound, Boolean
forIntrospection, Boolean suppressSecurityChecks)
at
System.Reflection.RuntimeAssembly.InternalGetSatelliteAssembly(String
name, CultureInfo culture,Version version Boolean
throwOnFileNotFound,StackCrawIMark& stackMark)
System.Resources.ManifestBasedResourcesGroveler.GetSatelliteAssembly
(CutureInfo lookForCulture, StackCrawIMark & stackMark
Sustem.Resources.ManifestbasedResourcesGroveler.GrovelForResourceS
et(CultureInfo, culture, Dictionary'2 localResourceSets,Boolean
tryParents, Boolean createIfNotExists, StackCrawIMark& stackMark)
at
System.Resources.ResourceManager.InternalGetResourcesSet(CultureInfo
requestedCultuire.Boolean createIfNotExists, Boolean tryParents, StackCraw
IMark& stackMark)
at
IMark& stackMark)
at System.Resources.ResourcesManager.GetObject(String name, CultureInfo culture,
Boolean wrapUnamanagedMemStream)
at Sustem.Resources.ResourceManager.GetObject(String name)
at (Object,String)
at #NBn.#oFe.InitializeComponent()
at #NBn,#ofe..ctor()
at #NBn.#oFe.ctor (#x unhandledExceptionHandled, #n report
ExceptionEventArgs)
at #NBn,#OBn. #ik(#ne)
at #m.#x.#pk (Exception, Boolean)
OK
