Is SQLBase by Unify Corp. compatible with Linux?
Does the database management system SQLBase by Unify Corp. is compatible with Linux?
I hope you can help me with this.
Thank you in advance!
Hi
The SQLBase allows us to develop and deploy on LINUX operating system,providing with a choice as well as opening new deployment market.
The SQLBase supports the various version of Linux which are as follows.
SQLBase 11.6 for Linux
Operating System | Supported |
Red Hat 5-5 | yes |
SQLBase 11.5 and 11Â for Linux
Red Hat AS 4 | Yes |
Red Hat ES 4 | Yes |
Red Hat AS 5 | Yes |
Red Hat ES 5 | Yes |
Suse Enterprise | Yes |
Hello Liezel,
SQLBase Database Management Software by Unify Corporation is compatible with Linux, and Windows.Â
Link given below will direct you to a comparison of Linux based Database Management Software widely used now:
And if you need more info or description  follow this link:
http://freshmeat.sourceforge.net/articles/sql-databases-for-linux
Hope this has cleared your doubts.Â
