Hi there,
For a week I have these kinds of errors. All are about 0x00000000005 types and I cannot solve them. Any expert can tell me please what is causing them ? What could be the problem with my PC ?
Thank you !
D:Program FilesCommVaultSimpanaBaseSrvOraAgent.exe
SrvOraAgent.exe – Application Error
The application was unable to start correctly (0xc000000005). Click OK to close the application
OK
Srv Ora Agent error application when starting
Your system could be hacked.
Try following steps: ( Do it at your own risk )
Start > Type ‘ CMD ‘ in search box > Enter > Type ‘ BCDEdit ‘
 if the result is : xOsload.exe you need to remove some files.
( It is necessary to reactive your windows afterwards )
Boot to Windows Repair – Command
Del D:WindowsSystem32xOsload.exe
Del D:WindowsSystem32xNtKrnl.exe
Del D:WindowsSystem32Driversoem-drv64.sys
attrib c:bootbcd -h -r -s
ren c:bootbcd bcd.old
bootrec /rebuildbcd
