SSF.exe a system error occurred
For a while it seems like I have some DLL file errors. For two days it started to appear on my windows startup and is. Nothing happens when I OK them but still. Can anyone help me please to fix these errors ? Why I have this errors and should I reinstall my Windows ?
Thanks !
SSF.exe – System Error
The program can’t start because d3dx9_43.dll is missing from your computer. Try reinstalling the program to fix this problem
OK
Answered By points N/A #175614
“D3dx9_43.dll” is part and parcel of Microsoft DirectX. DirectX is the greatest gaming platform giving the fastest speed and awesome graphics quality. The program “SSF.exe” was built using DirectX SDK so it is requiring the runtime.
Download the latest DirectX from Microsoft. Run the setup and install it.
If still no solution, first of all, use this DirectX Eradicator. This will remove all the DirectX files and registries from your PC. Then, give a fresh installation of DirectX on your PC. The problem should disappear forever.
