SSL Certificate Secure Connection Failed
How to fix facebook SSL certificate error? I already changed the date in my computer, disable my anti-virus, and turned off the firewall but still the same error message appeared. Do I need to uninstall my browsers? I used all the browsers that are installed here in my PC but the same problem occurred. What should I need to do?
Iogln.new.facebook.com uses an invalid security certificate.
The certificate as only valid for www.facebook.com
(Error code: ssl_errar_bad_cert_domain)
• This could be a problem with the servers configuration. or it could be someone trying to impersonate the several.
• if you have connected to this server successfully an the past, the error may be temporary, and you can try again later.
