Stacker s80 has been stopped working
Hello everyone,
I have used nokia 9500. I am using stacker s80 software for my mobile to increase disk space. But recently there has been an error is shown. I can't understand what is the problem . Please help me.
Answered By 60 points N/A #193818
Hi Kristopher,
How are you? Hope you are doing well.
Though you didn't mentioned what error you are getting in S80 but still generally it gives error if it tries to compress some application which don't allow compression because of file protection. So what you can do is deselect that application from compression and other way you can re-install S80 once, that may fix the problem.
Hope this will help you in solving your problem.
Thank You.
