Standard User Analyzer in windows 7?
Hello Peter,
The tool Standard User Analyzer (SUA) is used for testing of various applications. It is also helpful in monitoring the Application programming Interface calls mostly used to detect compatibility problems because of User Account Control in windows 7.
The Standard User Analyzer tool uses the Application verifier. As an example when ever you download any application the verification message pops out is because of Standard User Analyzer tool.
For more information and working of Standard User Analyzer tool please visit the link provided : https://msdn.microsoft.com/en-us/library/windows/desktop/dd744768(v=vs.85).aspx
This will help you.
Thanks
The Standard User Analyzer lets you to test applications to decide if they might have a compatibility issues caused by User Account Control.
The Standard User Analyzer offers data about problematic files and APIs, registry keys, .ini files, tokens, privileges, namespaces, processes, and other related items that the application uses that might cause difficulties when running on a computer with Windows 7 installed.
To use the Standard User Analyzer, start the tool, specify the target application, and then click Launch.
Thank You,
John Major.
