jabez zion
10 points
Posted on - 11/05/2012
We would like to see this reported as failures on account of they are right.Â
The way we can resolve by perusing documentation is to have our particular standardize pcx files documents on foundation of the implanted Tk.pcx index.
On the other hand, this document does not exist emulating documentation underneath.
We do see Blt.pcx and Expect.pcx but no Tk.pcx with the form TclDevKit5.2.1.293752.Â
Standarize pcx files for embedded app
Hi Jabez Zion!
Here is some clarifications, and you will defiantly find the mentioned files.
The TCl and TK syntax definitions are deeper intertwined with the core checker code than other packages. As such their definitions are in the core Tcl.Tcl core TK.Tcl files,and not .pcx files.
You can use gzipped tar format. The ZIP file listed under the windows sources contain the same information.
TK sources (tk8.0.5.tar.z)
Hope you will satisfied with this.
