The StarBurn burning engine could not be initialized
Hello trouble shooter,
I am not a technical person, don’t have much knowledge. I have a problem with StarBurn; I downloaded from the licensed website. But I am not able to initialize, I ended up with an error message. I double checked it CDBurnerXp is perfectly installed, but still I am getting this error. Anyone else is facing this kind of error? Please help.
The StarBurn burning engine could not be initialized, CDBurnerXP will not work.
Make sure that CDBurnerXP is installed properly, re-install if necessary. If you are using the portable version of CDBurnerXP, try the regular setup package instead.
Error details: Exception from HRESULT: 0x800402A7
