Hello experts,
Star craft battle cruiser paper craft game software is not working. Can you help me troubleshoot my star craft battle cruiser to get this working again?
I installed the game in my computer dell desktop with windows 7 starter operating system, when I click on the shortcut game icon it never loads the game.
What will I do now?
Starcraft battlecruiser papercraft game software is not working.
Hi Pamela Gonzalez,
Check first the compatibility of your software, some older games doesn’t work in windows 7. Just right click the game icon and select troubleshoot compatibility. Windows will automatically adjust the settings of your games.
You must read the specification requirements of the games for you to know exactly what environment does your games needs.Â
Yes, that is a common problem for windows 7. If you use windows 7 then some games will create problem.
If you want to ignore that problem then you need to follow the instruction given in the game. If your system fulfills all the requirements then you can install and play the game perfectly.
