chella
200 points
Posted on - 06/11/2011
Guys please help me with this.
I can't get on the Internet. Every time I shut down, the BSOD shows up. I can't even use the start up repair because it goes right back to the BSOD.
Heres the specs of my desktop:
eMachines
Vista Home Basic
NVIDIA GeForce 6150se
2GB DD2 RAM
pheetong
Start up BSOD problem any solution?
After a quick search in Google. It looks like you have a failing motherboard. There could also be memory related problems.
Try to download Memtest86, burn it to a CD and boot to the CD and let it run.
chella
200 points
Thanks for your suggestion Mr. Pheetong. But, I can't burn the file. I don't know why.
Please help me with this.
Thanks
june_07
What application did you use to burn the files? If you can't burn it. You can use a flash drive. You can download the pre-compiled USB installed.
Good luck
chella
200 points
I use Cyberlink Power to go. Should I change It? Please give me another alternative burner. Sorry I'm not familiar with pre compiled USB.
pheetong
If you can't burn the file then try this one. I'm pretty sure it will help you.
First download the BlueScreenView. Then Unzip the downloaded file and double click on bluuescdreenview.exe file to run the program. After the scan,go to edit then selectall. after that, go to file then save selected items and save report as BSOD.txt.
chella
200 points
Thanks guys!!! problem solved. Thanks to this site. Another problem solved in this website! more power!!!
