Starter Background Changer Win 7
I used StarterBackgroundChanger few months and then I made an "upgrade" from Starter to Home Premium, although StarterBackgroundChanger is uninstalled,i face the following problem.
Impossible to apply the funds of the themes for Win7.Only changes the color of the Aero ,whenI go from one theme to another. The changes that I request are properly validated,have not taken into account.
What can I do?
Thank you.
Answered By 15 points N/A #79262
There are many way to change the background of Windows 7 Starter Edition on Netbook. For you short listed to 3 way.
Go through the below information take advantage to change the background of Windows 7 Starter.
1)        Oceanis Change Background Windows 7
Oceanis Change Background Windows 7 is a small free program that lets you change background of Windows 7 Starter edition easily. This free software even lets you create a slideshow of images for your desktop. Just run the exe file, restart the computer, and change your desktop. It’s that easy. You can read more details about this program
2)        Change Windows 7 Background with Stardock MyColors
3)        Play with your registry entries
This is a bit tricky way, and should not be tried by everyone. This involves playing around with your registry entries to change wallpaper there
