Startup Error on Fedora 10: Could Not Determine Default Hypervisor
I am using Fedora 10 over my computer system though I am trying to get install Xen. However, VM supervisor is unable to find hyper visor and generates an error message attached as follow.
Error determining default hypervisor
Could not populate a default connection. Make sure the appropriate virtualization packages are installed (kvm, qemu, etc.) and that libvirted has been restarted to notice
the changes.
A hypervisor connection can be manually added via
File->Add Connection
In order to get fix it I thought by making manual connection it might get solves the error though nothing happened well. I in hope I get a solid solution regarding this error.
