alwyn white
20 points
Posted on - 03/30/2012
I having trouble with my Mozilla Firefox browser.
It is having some startup problem. Each time I double click on it I can see it opened in the task manager however I do not see it anywhere.
I need to know how to solve this problem.
Should someone know of this problem kindly inform me please.
Alwyn White
Startup error task manager shows active not visible
Hi there,Â
It seems you are having trouble with Mozilla Firefox and cant open it.
There are 3 Causes for this problem and 3 solutions :-Â
1. You ran our of memory (RAM) :-Â
Just Google for RAM cleaners and then download or install it if you don't want to spend additional money to buy and add a new RAM to your PC.
2. You PC is running full of viruses :-Â
Its really horrible and tough to fight with viruses and only a PC expert geek could do remove SOME of the common viruses.Â
Better install a GOOD Antivirus and or Internet security.Â
I personally Recommends Kaspersky Internet Security 2012. It works great. It catches almost all the viruses and also very smooth to operate. What problem Kaspersky has till its 2011 versions was slow updates. Now they have solved the problem.
Go try download the trial version and try it for 30 days and if and only if you liked then buy the license for 1 year.
3. Mozilla crashed. RE-install Mozilla Firefox.
