Startup problem on my computer
When i start my computer the screen with intel processor appears….before it used to b on full screen but from few days it is coming only on half of the screen and also all my games have started coming on half of the screen…what exactly is the problem…can u help me…i think it is my processor which is creating problem….or the window
Answered By 0 points N/A #177767
Hello  Aunshaa,
I think that it is not a problem of your computer but it is a VGA problem as you are able to see the half of the screen so in my opinion you need to check the VGA of your computer. There can be many reasons for this problem may be you have changed setting in your computer earlier for graphics so try to get them back also check your monitor first to make sure it is working fine and I think that you will be able to solve this problem.
Darrel R Gonzale
