Stat Calculator Unhandled exception has occurred in your application
How can I find where the issue is with the following error message? I have been getting the Stat calculator error message whenever I reboot the machine.
I click on Quit and then open a browser and the message box pop’s up again. I am using FireFox on my Windows Vista machine.
Can you please suggest some ideas?
Stat Calculator
Unhandled exception has occurred in your application. If you click Continue, the application will ignore the error and attempt to continue. If you click Quit, the application will close immediately.
An error occurred creating the form. See Exception.InnerException for details. The error is: Could not load file or assembly ‘Microsoft.VirtualBasic.PowerPacks.Vs, Version=9.0.0.0, Calture=neutral,
PublicKeyToken=b03f05f7f11d50a3a’ or one of its dependencies. The system cannot find the file specified.
Answered By 0 points N/A #114614
Hi James,
Stat Calculator un-handled exception has occurred in your application. If you click Continue, the application will ignore the error and attempt to continue. If you click Quit, the application will close immediately.
I am going base your error message, for my suggestion. This means, that the files you want to run are not really installed in your system. So I suggest, before you open or run your file, make sure that your file is in your system or did you do something wrong on your system. Maybe you renamed your file, when you tried to open your file. Just restore your file name then, run it again.
This would help.
Thanks
