Hi all,
I am getting crimped of Steam and their errors. When I try to play in offline mode somehow I am getting this error message. And it wants to connect to the internet, tired again after connecting same error message appears again. I don’t find any reason for this. Any help would be appreciated, thanks.
Title: Unable to connect to the steam network.
Unable to connect to the stream network. “Offline mode” is unavailable because there is no Stream login information stored on this computer.
You will not be able to use Steam until you can connect to the Steam network again.
Steam fails to start offline mode
When using Steam, make sure you are not running Microsoft Windows 8 and later because it is not yet supported. To make sure you are using an up-to-date client, download the latest version from Install Steam Now. The latest version of the client supports Windows XP, Windows Vista, and Windows 7. For Mac users, it supports Mac OS X 10.5.8 Leopard, 10.6.3 Snow Leopard, and higher.
For Mac users, download Steam for Mac. For Linux users, download Steam for Linux. Uninstall the version you have on your computer and install the latest version. Once installed, try it again and see if it works. If the same error appeared saying that there is no login information saved on your computer, this is probably because you haven’t created an account yet on Steam.
If this is true then you need to create an account to fix the error. Creating a Steam account is absolutely free. To create an account, visit Join Steam. Once your account is created, try logging in to your account using the Steam client. This will eventually store some login credentials and or information on your computer which can then be used by your game to be playable offline. See if this works.
