Steam Startup failed with error 0x0034E608
Asked By 15 points N/A Posted on -
Hi there,
When I want to launch GMod 13 Beta this error appears. I have rebooted the PC to delete to reset the cache memory and it doesn’t seem to work. I have verified the registry with a software and it works OK. Can anyone please help me to solve this? What is with this error message? Thank you!
Error!
Steam startup() failed: SteamStartup(0xf,0x0034E608) failed with error 1: The registry is in use by another process, timeout expired
Ok
Answered By points N/A #184491
There are several causes that make this trouble.
The main problem is confliction with other programs. There are many programs which causes this error.
Check here those applications and close if you’ve got any before running Steam.
Also, viruses might cause this error because their work is to make programs crash. Use any good antivirus such as, Norton, Avast, Kaspersky, AVG etc.
Also check your BIOS for proper configuration. Contact with your manufacturer for resetting BIOS settings to default mode.
Also, re-install the software. Then see your problem will be surely solved.
