effieclyde
10 points
Posted on - 05/23/2013
Hello Techyv members.
I'm trying to back up and restore my physical and virtual machine.
I need step by step instructions on VMware disk mount Appassure 5.
Can someone here help?
Any help would be much appreciated.
Thanks in advance.
Step by step instructions in VMware disk mount Appassure 5
Hi Effie,
If you are aware what the needed requirements would be you can start off using Appassure Core Console, given that you already installed it in your server.Once installation is done all you have to do is access it by navigating your browser HOSTNAME:8006/apprecovery/admin and then log in with your administrator account details.
Then you can set your Appassure manually however, you can click on Setup Core to guide you through configuring all the parameters and functions. You can also set this to have email notifications where you can customize the message that you are sending out.
Then go to Repository so you can define where you want your backups to be saved you can also add more disk on it.
