jabez zion
10 points
Posted on - 05/02/2013
Hi guys! Unity was known for developing video games on desktops, mobile handsets, consoles and others. One of the best feature that I was impressed was the mask 3d max. But I don't know how doing it. Does anyone of you guys know any step by step tutorial on how to do it? Is not a video tutorial would be ok.
Step by step Mask 3d max tutorial.
Hi Jabez,
Masking is definitely one of the most amazing feature of 3D max and also one of the most difficult part to make. I have provided a link below where it does not only shows a step by step text instructions but also illustrated pictures you can follow.
Masking Effect in 3D Max
Here's another way of doing it by using the Mask Map:
Masking Effect Using Mask Map
I hope this will help you in creating the mask effect in 3D Max.
Hello Jabez Zion,
Sir if you want to learn the software in a complete way then you can need to go to the website given below all you need is to download the video tutorials. There are many of the categories from there you can get what you want. It is a free of cost web for the learners and also a best way to learn the software. So I suggest you to see these I hope that they remain good for you.
https://www.hongkiat.com/blog/the-ultimate-collection-of-3ds-max-tutorials/
