Steps About How To Make A Check Mark In MS-Office
Hi. I am a new user of MS-Office. I want to make a check mark. How to make a check mark? Please reply ASAP. Thanks in advance.
Hi. To learn how to make a check mark, you can use the symbol command by clicking on insert menu and then clicking on symbol from the group named symbols. Next, click on Wingdings from the symbols menu. Then, from the symbols provided, select the one which is needed by you by double-clicking on it. You can also use AutoCorrect by clicking on the insert menu and then clicking on symbol from the tab. Then, click on Wingdings. Select the symbol which is desired by you and then click on the autocorrect option.
The symbol which you have selected will appear in with box. Type a word which you want to link with the symbol in the box named replace. Then, click on the add option after which click on OK. Whenever this symbol needs to be added to any document, just type the word which you used in the replace box.
Hope we helped.
