Steps in Access 2003 repair indexing
Hello everyone! Does any of you know how to fix Access 2003 repair indexing? I need your step-by-step in fixing this and something easy to follow please, thanks!
Following are the step-by-step method to repair Access 2003 using Access Recovery Toolbox
1.      Run the application.
2.      Select the database to be recovered.
3.      Click on OPEN button and choose the file by manually typing path/directory in the drop-down list.
4.      Browse the data structure to be recovered.
5.      Browse properties of each database object.
6.      Select the target database to be saved. This will be done after application reviews the structure. Afterwhich, you will be prompted to specify the path and file name. Press the SAVE button
7.      Press the RECOVER button to start up recovery
8.      You will view the recovering process program.
9.      Complete the process by clicking on EXIT if viewing of journal recovery is completed.
I do hope that these steps shed light to your troubles.
